After multiple successful builds for enchilada and, I am facing the following error:
[100% 1/1] analyzing Android.bp files and generating ninja file at out/soong/build.ninja
FAILED: out/soong/build.ninja
cd "$(dirname "out/host/linux-x86/bin/soong_build")" && BUILDER="$PWD/$(basename "out/host/linux-x86/bin/soong_build")" && c
d / && env -i "$BUILDER" --top "$TOP" --soong_out "out/soong" --out "out" -o out/soong/build.ninja --globLi
stDir build --globFile out/soong/globs-build.ninja -t -l out/.module_paths/Android.bp.list --available_env out/soong/soong.e
nvironment.available --used_env out/soong/soong.environment.used.build Android.bp
error: vendor/qcom/opensource/vibrator/aidl/Android.bp:4:1: "vendor.qti.hardware.vibrator.impl" depends on undefined module
"qti_vibrator_hal_defaults"
17:34:58 soong bootstrap failed with: exit status 1
#### failed to build some targets (01:49 (mm:ss)) ####
Could also be an upstream problem?
Ideas or clues how to fix will be greatly appreciated.
Thanks!
