I think this is the GSI build? This thread is for device specific builds (official and unofficial), but it would be good to put the S21+ on the GSI support page. That table should be editable, so you can directly add your device to that list.
Unofficial builds are now available for two previously unsupported Sony devices, both at Iodé 7: Xperia 1 IVpdx223 and Xperia 5 IVpdx224
Apologies, but I don’t have the patience to edit the table at the top of the thread
hi im iodéOS maintainer for poco f6/f7 for some months ![]()
if possible, edit unofficial list and add this:
Onyx/Peridot builds: iode - Browse Files at SourceForge.net
Done. The ‘Tested’ column currently says ‘?’, because I didn’t know what testing you have done. I think you should be able to edit the table yourself to change that
yes, I always test my builds, i never post before testing, i’m always the first ![]()
here you can see my posts: Telegram: View @degoogl
this is one of two ROMs that i maintain, and i use iodéOS on my device
my ROMs are posted on many channels, and im always providing support regarding bugs that occur due to my fault, questions, etc.
Thanks. I’ve updated the table to reflect that
