I would like a custom mode to be active only for a certain amount of time.
I had this option with /e/OS, but I can’t figure out how to do it with iodé.
I would like to stop certain messaging notifications so I can work, but I don’t want to log out completely.
MissPiggy :Thanks, that’s interesting features and I’m having a look around ….
But I’d like to know if it’s possible to set a mode (silent mode, for example) for a specific period of time only. And then have it automatically switch back to normal afterwards.
That’s what I used to do on my Murena. Silent mode for 1 hour…
Yes this is the default behavior when you just tap “Modes > Do Not Disturb” from the pull down “Quick Settings”.
You can check settings from “Settings > Modes > Do Not Disturb > Duration for Quick Settings” where you set it to a default (1 hour) or instead to “ask every time”. Then when you enable from drop down / quick settings as noted it will just turn on for preset time, or instead pop up to ask how much (if that is what you set). After it ends, it goes back to normal.
