DNS CNAME cloaking & iodé blocker
Hi!
Does the iodé blocker detect and prevent CNAME cloaking (as for example RethinkDNS or personalDNSfilter are able to)?
no.
that’s why i use pdns
Are there any plans to make the iodé blocker capable of dealing with CNAME cloaking?
I asked that 1 year ago… but it doesn’t look like it
Does anybody know if CNAME cloaking is only used on websites or in apps as well?
If it is used only on websites, then there would be no need for an additional DNS filter when using uBlockOrigin since it can handle CNAME cloaking (only for Firefox based browsers).
in apps too.
you can test it with these tools
Thanks!
