Display flashes on Fairphone 5 after installing IodeOS 6
Hello
Thank you for the release of iodeOS 6 !!
I install it. It is fine except that the locked screen flashes sometimes
(I mean the in between screen, with the top menu)
Is it because of the AOD ?
Thank you for your help !!
(I try to post an issue, but I cannot connect to Gitlab
It seems it is due to “Pin media”
If I turn it off, it sorts the issue
I eventually found that it was due to an app that was not correctly stopped
Sorry for the “useless” post
Glad you solved the issue. No need to apologize, this could be useful for someone else that has similar issues.
