Hallo, I have several Sound-Problems on my Samsung S10 (all updates made, it was from beginning on….)
1.) when I use the Speaker I can hear, but my phonepartner doesn´t hear me anymore. Same with headphone.
2.) when I open a voicemail at Signal or Whatsapp it starts “loud”. When I then take it to my ear so no one else can hear it, it stops or it is way to loud. Ich tryed different things, but I don´t find the “rule” with that this works. So either I hear nothing, or it hurts in my ears and/or everyone else can hear everything…..
3.) Most of the time I don´t get a sound for incoming calls. No difference if it is a normal call or a Signal or Whatsapp call. Only sometimes there is a sound. Sometimes it is while I read for example something at telegramm…but sometimes I do nothing or hear a Podcast. At least I don´t understand the reason why or why not….Usually I get sounds for incoming messages as expected.
I read about some people who had some similar problems but I couldn´t find a solution yet….
I added “Samsung S10” to the title and also tagged that device. Let’s see if others with the device can give some feedback. Can you link the other threads you have seen about the issue? Maybe we can consolidate them to help us get a bit farther down the road on this issue.
I wonder who installed the iodéOS in the first place (Miso states, he/she bought it with iodéOS already installed) and if maybe a clean, new install could help. The other day, we solved a problem with updates (thread was in German), but I kept wondering if there was more to the problems than just inexperience with Custom-ROMs. But of course, if Miso bought it from iodé, then this should not be an issue - if he/she bought it from a private person, it may well be.
I bought it from iodé, so maybe you are right and i should send it back, i never thought about that before… the other thread didn´t get solved, but i wrote privat with the person who had the problem, his / her solution was also to send it back. So I guess I will do that. Thank you for your help!
Oh ok, then I missunderstood. But since that problem existed from day one on that could maybe help….since I have no other idea. And as you now I make my updates regulary, as soon as possible.
Du hast ein gebrauchtes Gerät vor 1,5 Jahren gekauft, das von Beginn an Lautsprecher bzw. Mikrofonprobleme hatte, soweit ich das bisher verstehe. Hattest Du es damals reklamiert? Es ist ja bei wiederaufbereiteten Geräten immer möglich, dass doch eine Hardware-Komponente einen Schlag hat, die bei der Endkontrolle nicht auffiel.
Selbst bei ganz neu gekauften Geräten macht man immer zunächst eine Kontrolle, ob alle Taster und Kameras, Mikrofone usw. funktionieren.
Ob es vielleicht doch kein Hardware-Problem ist, sondern eine Einstellungssache in der Software, das ließe sich herausfinden, wenn Du Riks Vorschlag aufgreifst und die Threads verlinkst, in denen Du über ähnliche Probleme gelesen hattest. Und vielleicht auch das Problem nochmal genauer beschreibst (“don’t get a sound for incoming calls” - bedeutet das, es gibt keinen Klingelton oder dass Du die Gegenseite nicht hören kannst, wenn Du das Gespräch annimmst?)
Bitte nimm den "Lösung"s-Haken wieder raus, danke.
