huuhaa
9 September 2022 16:16
1
Please add support for Motorola Edge 20 (berlin)
Basic
Spec Sheet
CPU
Octa-core: 1 x 2,4 Cortex-A78, 3 x 2,2 GHz Cortex-A78, 4 x 1.9 GHz Cortex-A55
Chipset
Qualcomm Snapdragon 778G (SM7325)
GPU
Qualcomm Adreno 642L
Memory
8 GB
Shipped Android Version
11 (R), upgradable to 13 (T)
Storage
128 GB, 256 GB
MicroSD
No
Battery
Li-Po 4000 mAh, non-removable
Dimensions
163 x 76 x 7 mm (6.42 x 2.99 x 0.28 in)
Display
6,7 inch OLED, 1080 x 2400 pixels, 19,5:9 ratio (~385 ppi density)
Rear Camera
108 MP, f/1.9, (wide), 1/1.52", 0.7µm, PDAF, 8 MP, f/2.4, 79mm (telephoto), 1.0µm, 3x optical zoom, PDAF, OIS, 16 MP, f/2.2, 17mm, 119˚ (ultrawide), 1/3.06", 1.0µm, AF , LED flash
Front Camera
32 MP, f/2.3, (wide), 0.7µm
Device picture
Resources
https://wiki.lineageos.org/devices/berlin/
Hi Mika nice to see you here, too
Maybe it will supported some time…but i think not in the near future
huuhaa
9 September 2022 21:53
3
Hi!
Actually this request is bit more for friend of mine, bit cause I could consider this device with now lowered price for myself too, evethough currently leaning more toward certain gsi
But more options for OS is always good thing and not many newish phone are supported by LineageOS. Anyway if this device is someday supported, I think there could very well be possible users out there.
I made an unofficial build if you want to try:
iode-4.10-20240322-berlin.zip
https://sourceforge.net/projects/eosbuildsronnz98/files/OtherCustomROMS/iode-4.10-20240322-berlin.zip/download
Install instructions can be found on LineageOS page
