My phone (Samsung Galaxy, I bought here in the store) has unfortunately fallen down.
Apart from a few flashes, I no longer have a display.
Is there any way to recover data from the memory card? Windows does not read the card.
Thank you very much
Thank you very much
You can try to make a bootable usb key with linux (linuxmint for example).
With Linux loaded, you could be able to access your memory card and recover your datas.
The other option is to install drivers for linux system partition on windows.
Thank you!
If you have a TV device with an HDMI port, you can get a USB OTG switch with an HDMI output and other USB ports. Then you can connect the smartphone to the TV and work with it with a mouse and keyboard.
