I have tried to activate a esim, it dosnt work. Aktivating through the Congstar-App dont have sucess and even scanning the QR-Code in openEUICC failed. Tested 6.9 and 7.0.
It was working on Stock ? Or did you buy this phone with Iodé ?
Esim did not work for me on stock. I had to call my provider for activation. They said its common on esim.
On Iodé its worked out if the box (P9a).
Its not working on Stock
Stock Google Android or Stock Iodé Android ?
Anyways.. call Congstar with another phone and let them activate esim. Thats how I did it.
On both Stocks. Congstar could not help.
problem solved. I read out the QR-Code with QR-Code-Reader and entered it manually.
Now my esim is installed and works fine
Thanks for reporting back here. I didn’t know of QR Code Reader, interesting find. Was it something like this or other?
exactly
