Hello, I don’t have a Iodé/OS yet.
May I ask you where are the contacts saved ? Only on your device, or they are saved on another place, or perhaps synchonised with Dav5x ??
Currently on my mobile, all contacts are sync with a cloud provided by the manufacturer ( Murena.io). But it has an outage since October and I took a copy in .vcf format
If your own Nextcloud is too complicated for you…and you only want to synchronize contacts and calendars…take a look at Radical…small server software for CalDAV, CardDAV.
I run it on a raspi.
Radicale is a interesting solution. Thanks. But I already have a lot of files on a Nextcloud instance by Zaclys. I’ll try to sync my contacts in that direction as soon as possible…
In conclusion, iodéOS does not impose any systems to save our contacts on a cloud, but certainly propose a pre-installed app to manage them
My bet is to use MyPhoneExplorer from MyPhoneExplorer | Functions and GoogleAppStore.
It can create a local account for all your contacts.
Synchronizes directly phone and other computers, wired or OTA. Without intermediate clouds.
