Contact Mixup for calls and messages / Mauvais contact
Depuis ce matin, sans mise à jour (iodé 6.5)
J’ai essayé d’envoyer des messages à un contact n°1 (SMS et MMS) or les messages étaient envoyés à un autre contact n°2
J’ai redémarré le téléphone, j’ai essayé d’envoyer le message en passant par les contacts, en répondant à un message existant, en créant une nouvelle conversation et en renommant les contacts. J’ai vérifié si ce n’était pas une conversation groupée
Et cet après-midi, en voulant répondre au contact n°2 qui recevait les messages, c’est un 3ème contact qui recevait mes messages. Alors que ce matin, quand je répondais au contact n°2, c’est bien lui qui recevait mes messages
Pensant que cela venait de l’application “Message 1.2.1”, j’ai voulu appeler le contact n°2 or c’est le contact n°3 qui a été appelé
Avez-vous une idée car c’est vraiment très gênant ?
translation of original post:
Since this morning, without any update (iodized 6.5)
I tried to send messages to a contact n°1 (SMS and MMS) but the messages were sent to another contact n°2.
I restarted the phone, tried to send the message by going through the contacts, replying to an existing message, creating a new conversation and renaming the contacts. I checked that it wasn’t a group conversation.
And this afternoon, when I tried to reply to contact n°2 who was receiving the messages, a 3rd contact was receiving my messages. Whereas this morning, when I replied to contact n°2, he was the one receiving my messages.
Thinking it was coming from the “Message 1.2.1” application, I tried to call contact no. 2, but it was contact no. 3 who was called.
Do you have any ideas, as this is really annoying?
Very strange! I think we need to see if anyone else can confirm this. I have known of a similar issue in years’ past but that was with Ubuntu Touch, and that time it was also in combination with my cellular carrier force converting SMS / MMS to RCS behind the scenes, so we disabled RCS and it “fixed” the issue.
C’est très étrange ! Je pense que nous devons voir si quelqu’un d’autre peut confirmer cela. J’ai eu connaissance d’un problème similaire il y a quelques années, mais c’était avec Ubuntu Touch, et cette fois-là, c’était aussi en combinaison avec mon opérateur cellulaire qui convertissait les SMS / MMS en RCS dans les coulisses, alors nous avons désactivé RCS et cela a “résolu” le problème.
C’est de pire en pire cela le fait avec tous mes contacts
Je viens d’avoir une mise à jour Davx⁵, mais cela n’a pas résolu mon problème
Est-ce que les gens de iode vont investiguer sur mon problème ou je suis bon pour changer d’os ?
Excusez-moi SVP de répondre en Anglais.
I have vague memories of something like this happening to me a while ago, but I don’t recall whether it was under IodéOS or LineageOS for microG. I recall that I was able to fix it by clearing Contacts Storage and Phone and Messaging storage, then repopulating them from backed up call logs and messages, and synched contacts.
  1. All my contacts are synched to a NextCloud account using DAVx5. You could also try exporting them to a .vcf file from the Calendar app.
  2. Messages and Call logs exported using SMS Import / Export app
  3. Remove the NextCloud account in DAVx5
  4. Clear storage:
    • Settings Apps | Show all
    • Search for ‘storage’
    • Select ‘Show system’ from the ‘three dots’ menu
    • Open ‘Contacts Storage` then Storage and cache’, and choose ‘Clear storage’
    • Repeat for ‘Phone and Messaging Storage’
    • Maybe repeat also for ‘ContactsKeys Storage’ (I don’t recall whether I did this or not - it was a long time ago :slight_smile: )
  5. Reboot the phone, just for luck :slight_smile:
  6. Repopulate Messages and Call logs from the SMS Import / Export app
  7. Repopulate Contacts by adding the NextCloud account in DAVx5 (or importing the .vcf file you exported from Contacts
I hope that helps. Bonne chance!
Thank you for your answer, i’ll try it as soon as possible
Finalement, j’ai changé d’application de SMS et je n’ai plus aucun problème.
(J’avais peur de perdre des messages importants)
Translation of prior post:
Finally, I changed my text messaging app and now I don’t have any problems.
(I was afraid of losing important messages.)
Glad that the problem is addressed, could you mark this thread as “solved”?
By the way, what app did you change to? I did see there is a new version of Fossify Messages (1.6.0) that has been released, I don’t know if it would have solved your problem or not.
Full disclosure, I use Quik as my default messaging app :slight_smile:
Je suis ravi que le problème ait été résolu, pourriez-vous marquer ce fil de discussion comme « résolu » ?
Au fait, vers quelle application êtes-vous passé ? J’ai vu qu’une nouvelle version de Fossify Messages (1.6.0) avait été publiée, mais je ne sais pas si elle aurait résolu votre problème.
Pour être tout à fait honnête, j’utilise Quik comme application de messagerie par défaut :slight_smile:
