CoMaps 2025.07.23-2 (iodeOS 6.6) crashes on POIs having OpeningHours
See #1325 - crash once selecting certain POI - potentially related to "Opening Hours"? - comaps/comaps - Codeberg.org
Looks like a specific issue to the bundled version in iodeOS, would it be possible to build 2025.07.23-4 and push into the “iodeOS apps” repo?
You can uninstall and install any version you wish, if you have the apk. Or just wait for the next release, or try the beta, as the iodé devs bring the system apps up to date every month.
It least on my side issue resolved on iodeOS since update yesterday to 2025.08.13-8 provided by fdroid.iode.tech
