Code PIN de mon espace privé oublié / inutilisable?
On my Fairphone 5 (IodéOS 7.2), I want to access to my private space to see if there are some Apps hidden in it. The system asks me for a PIN code, but none of the ones I could have used are valid. Actuallay, I don’t remember if I locked the private space wit ha PIN code when I discovered my new phone, bit I guess so, as it is locked.
Is there a solution to unblock this?
Thank you
If you want to wipe out your “Private Space” then I think that can be done this way “settings → security & privacy → private spaces → delete private space”
I don’t have this “delete” option. As soon as I select “private space”, a code is requiered…
It looks like it is possible to use “System Settings > System > Reset Options” to delete the private space
Perfect!!! Thank you very much!
