Summary: The iodé version of Heliboard blocks the update of the regular version. This was not an issue until the recent 3.7 release.
I use the standard version of Heliboard from F-Droid for reasons detailed in this previous post. Since it is seemingly not possible to remove the iodé version (it doesn’t appear in Pre-installed Apps), I have simply disabled it, but for the last couple of years I have simultaneously updated both versions from within F-Droid, no problem.
With v3.7 becoming available, I updated the iodé version first, but when I subsequently try to update the standard version, I get the message:
Error installing HeliBoard
Error - 13: The new package failed because it contains a content provider with the same authority as a provider already installed in the system.
OK
I’m hence unable to update the standard version from 3.6, which is a shame since it contains an emoji search feature that I’d like to use. I tried rebooting, that makes no difference.
On a Fairphone 3+ running iodéOS 6.12. Just updated to 6.13, same problem.
