Choix de la puce GPS (galileo)
Bonjour, peut-on choisir ou forcer le GPS sur Galiléo, le GPS européen ?
Merci
I am not an expert (don’t use GPS myself), but I think it is not possible. I know that there are apps like GPSTest | F-Droid – Freies und quelloffenes Android-App-Repository that at least show you if your device is able to receive signals from Galileo, but you cannot force it to use Galileo only.
