Device name: Devon(moto g32)
iodeOS: 7.3 latest build(7.3-20260304
Brief Description:
Hello devs! I encounter a bug regarding charging my device(moto g32). The bug is:
If I charge the phone with proper USB C Charging cables(tested on multiple devices with multiple USB C including default moto g32 USB C cable), at first it charging normally but when I unplugged and replugged the USB C, there are no vibration sound and charging indication(green) and the device stop charging until I reboot the device multiple times.
These are all the issues I encounter as of now and will provide logs if required.
Thank you ![]()
Step-by-step reproduction of the issue:
Charge your moto g32
Now unplug your moto g32
Replug it again
Do this couple times or more
You’ll notice the bug
Expected behaviour: Should work normally as intended
Actual behaviour: Said issue
