Can I flash iodeOS on Mi 10T Pro with MIUI 14 installed?
The actual image is:
iode-3.6-20230401-apollon-fastboot.zip
MIUI 14 is based on Google’s Android 12. iodéOS 3.6 is based on LineageOS 19.1 (Android 12). Accordingly - yes you can install iodéOS 3.6 /3.7.
Is it unlocked?
Have you waited a week?
I thought MIUI is Android 13 and that I would mix Android versions. That’s not the case.
I haven’t bought a 10T Pro yet, but prefer it over a Pixel or Oneplus for the better battery lifetime.
After unlocking the bootloader and executing the flash-all.bat, I get errors like:
“userdata type is f2fs, but ext4 was requested for formatting”
CreateProcess failed: Das System kann die angegebene Datei nicht finden. (2)
error: Cannot generate image for cache
Warning: userdata type is f2fs, but ext4 was requested for formatting.
error: Cannot generate image for userdata
error: cannot load ‘ablbak.img’: No such file or directory
W/ziparchive(29144): Unable to open ‘iode-3.6-20230401-apollon-img.zip’: No such file or directory
error: failed to open zip file ‘iode-3.6-20230401-apollon-img.zip’: I/O error
rebooting…
finished. total time: 0.005s
Press any key to exit…
With a newer adb/fastboot version got into a MIUI Reccover bootloop.
Mixing all files into one folder and executing flash-all.bat not with a right-click, but from the command line, it starts flashing,
misses ‘(storsecbak) No such partition’)
and stops at iode-3.6-20230401-apollon-img.zip. (archive does not contain ‘init_boot.img’, ‘dt.img’, and so on.
From the lineageos-recovery I could sideload the normal iode-3.6-20230401-apollon.zip.
After a “Format Data”, I now have a working IodeOS ![]()
