Camera shutter sound ON / OFF?
This concerns the generic app that is used in IodeOS to take pictures.
I haven’t found a way to shut off the sound of the picture shooter. Each time I make a picture, there’s the sound of it. I’d like to disable that sound. I didn’t find the option in the various menus of the OS, and I find it annoying.
Has somebody got a solution ? Shall I’d better change my camera app then ?
Thank you for your tip or help.
Settings
Shutter sound
Thank you for your proposal.
I don’t have the option for the shutter sound from the settings of the camera
I use the 5.6 Iode OS and my developper options are activated, for those who could help me out.
Ty
what is the name and version of your camera app?
Mine is Version 1.0-iode.29
com.iode.aperature
I also use iode 5.6
It s a version from lineageOS as shown on the screenshot. I haven’t seen any way to uninstall yet the camera app.
I got the app, as the camera app developped by the Iode team from the f-droid store. I just uninstalled and reinstalled it, same result, I m still with the same menu options. :smiley:
All right, I switched to another camera app that allowed me the option I mentioned earlier.
I’ll see someday if I ll have the option back with the original app…
I just installed it from the pre-installed apps… same result as laneb …
switch is there.
try it like this
I did it a couple of time and rebooting my phone at each change.
I’ve got the same result as I previously had. I hope the quality of my picture won’t be too altered.
Anyway, I can state the frame of the standard picture app was anyhow too small.
I’m coming back on the trouble I found on my phone. Has someone got an understanding of my problem ? Have I done something wrong with the install of the Iode OS ? Has it already happened ? I don’t believe I installed LineageOS + MicroSG…
Shall I try to reinstall Iode OS ? I just got today the 5.7 update, hoping something would have been fixed, but none in vain.
Thx for your tips :slight_smile:
If I look at the settings oft my app, it says
Version 1.0-iode.29
com.iode.aperture
Yours is a Lineageos version
Org.Lineageos.Aperturen
So we talk about different apps
The shutter sound is forced in Android to comply with law in some countries (MCC 404, 405, 440, 450). The LineageOS Aperture app respects this constraint.
you could try an automation app that silences the phone (or better: only the channel the shutter sound is using) when you open the camera app.
Personally, I’m using Tasker (which is paid), but from the description, Automation should do the trick
Hello, yes I know. Each time I use the preinstalled menu for the camera app, my phone installs back the lineageos camera.
I didn’t find a way to install the preinstalled version you’ve all (mostly) got.
Is there an apk for the version you got. Here’s what the lineageOS version looks like. (screenshot)
The LineageOS version is the one to use, no need to install the external app. This external app was provided for interested users when the default iodé camera was based on OpenCamera.
Ok. I’ll look through the documentation of this app “Automation” from the f-droid store, to see if and how I can shut down the shutter sound with those command lines…
It seems there’d be also a possibility to root the OS (Iode OS with Magisk), so as to set the shutter off.
Ty
Yes.
However, my troubleshot is to find a way to set the shutter sound off…
Impossible to take cats pictures without in those conditions…
So I tried to install Aperture from the f-droid store, independantly to the one of the OS, from the preinstalled apps menu, I will get the same menu that is shown on the 4th post of this topic.
I can also return to the OpenCamera app.
Ok cat pictures convinced me. You can find here a new version of Aperture, with forced shutter sounds disabled: fdroid/repo/Aperture-30.apk · master · fdroid / fdroid · GitLab
You can install it through f-droid too. And you can uninstall the actual camera in the preinstalled apps settings.
