I received a news about iodéOS 6.0 release with Camelot PDF replacing PDF viewer plus. I intalled the 6.0 version and then even the 6.1, but my PDF viewer is still the same. And it is impossible to find “Camelot” on Aurora or F-Droid stores. Is it normal or will Camelot be released later?
Thank you very much
try this
Open the settings
Go to “Apps” and then Preinstalled Apps Productivity
select pdf-viewer install
reboot.
Same thing here: FP4 with Iodé 6.2. PDF app was the same than before the latest update and before older updates I have just uninstalled, and installed it again from the Settimgs->app…s->preinstalled apps, amd rebooted. But is still the same app, no trace of Camelot.
per this reddit, camelot doesn’t have a launcher icon. Its just a basic pdf viewer
https://www.reddit.com/r/LineageOS/comments/1hr8omg/where_are_twelve_and_camelot/
