I’m looking for the list of calls + duration for a contact: how do I go about it?
On Android, there is normally a menu in the contact that allows you to do this.
On iodé, I haven’t found it…
iodé: 4.8-20231216-apollon
In the phone app select call history, Scroll through the list to find someone, tap on the name to get an options menu and select call details.
I don’t know of any other way.
I’d found this trick but it forces me to search for all the calls one after the other ;-(
What would be nice is to be able to have the list of calls and their details from the contact.
Thanks for your reply!
