[bug] Unreachable Wifi when SSID is hidden
Connection succeeds to any wifi but becomes impossible when SSID is turned hidden: BraX3 then don’t see the network.
This has already been noted on Brax3 forum, within many other wifi issues, so has it been investigated?
I don’t see this subject yet on iodé Github.
So at the bottom of the wifi / internet settings, when you click “Add network” and type in the SSID of your hidden network it isn’t found? This should be working, maybe you can clarify more the steps you are trying. Maybe you are specifying the wrong security format, for example?
Alright. I was wrong, I succeeded by setting the network manually AND selecting the “hidden network” choice on in the advanced settings.
Before that, I was joining by a QR-code, which works correctly with the other phones.
Good to know you were able to connect. I believe I have shared and received QR codes to connect to wifi, it may need another test.
