there is a bug with the following application since the last update of iodine os beta: version 2021-11
com.android.intentresolver
unable to share a web link between applications.
anyone experiencing the same problem?
What beta version exactly did you install?
I have FP5, running 20250122 and I have the same problem. No sharing at all is possible.
I was running an earlier Iode 6.0 beta and at some point sharing DID work. So its either a bug that has been introduced in the last beta (depending on what version you actually installed) or its an app that we have in common that has broken it.
probably that, no root in iode though, so I guess have to do another full wipe.
6.0-20250121-oriole
AP4A.250105.002 dev-keys
Some good news, its a bug in LineageOS that has been resolved: https://review.lineageos.org/c/LineageOS/android_packages_overlays_Lineage/+/416577
When Iode pull in LineageOS next and rebuild, we should be good.
Hopefully the Iode devs are aware of this also
I believe Vincent has already applied the fixes and some in the matrix chat confirmed that sharing is now working again.
the beta version of January 25 actually corrected the problem. thanks for the speed
