Breezey weather won't update
Hi, how do I remove breezey weather , I’m fed up of it not updating. Preinstalled apps only pause it until the next restart and then is reinstalled. Even disable isn’t possible
I’ve not used it as I prefer the met office app.
I just want rid of it.
Settings → Apps →Preinstalled apps
You can uninstall most built-in apps there
Thanks, it waiting for a reboot, which I did but didn’t until I rebooted again a few moments
Ken
