Hello
I would like to know if iodeOS takes charge of the battery sharing on a Google pixel 6.
thanking you for your return.
Hello
There’s no option under Battery settings, so no.
Its on my pix5 but not on pix6a
If I activate it on 5 it does not load the 6a
Some of this is device specific.
Pixels 6a, 7a do not have wireless charging.
5, 6 and 8 (I have one) have wireless charging.
However, pixel 5 only has wired reverse charging.
Have to edit that. I’m able to wireless reverse charge with redfin P5 running DivestOS.
I got my original data from GSM arena, but it’s wrong. In their specs they say wired reverse charging. Might be a typo tbf. In their review, linked from the same page they talk about it’s wireless reverse charging ability.
Pixel 6 and 8 have reverse wireless charging.
My 8 is on calyx at the moment until los 21 drops and iode upgrades. Then I build for it. It has the QS tile for “Wireless PowerShare” which one taps to turn it on.
I couldn’t find any app or entry in Settings for this.
It worked to charge pixel 5
Also worked on my Samsung S10+ with Iode. Just had to activate the quick action button and could charge my Galaxy buds
Tap it, see if it works. It would be nice to know.
I tried with an iPhone and it works !
