Battery charging control lost
5.5 beta
It appears that I lost the option to automatically halt charging at a preset level, e.g. 85%.
How can I reactivate this feature?
Greetz
Roland
Found the solution:
Charging control was (how, when? No clue) set to a sort of timer.
I could not change that. I could only adapt the times.
The solution was to disable charging control, and to set it again. There appeared to emerge an option of charging up to a preset level.
So, it worked.
But very much counter intuitive, and user-UNfriendly.
Suggestion: plus improve the menu structure
Greetz again!
