Bank apps do not work
I installed iodeOS 5.5 GSI (Android 14) on an Oukitel WP5 Pro.
Bank apps do not work. Is there a remedy to this?
check the microG settings, especially safetynet
Everything is ok there (default setting untouched).
Could it have connection to not removing dm-verity upon installation? (It’s not mentioned on iodeOS installation page, but I had /e/OS before and there they mentioned that too)
Solved. It didn’t have the seamless upgrade capability.
