Automatic Dark Theme
Since the update to iodeOS 6.9, the automatic dark theme with location data no longer works on my Google Pixel8a.
Under iodeOS 6.8, the automatic change at sunset or sunrise had worked wonderfully.
The location services including BeaconDB as an online service are activated. Location Search via Wi-Fi or Bluetooth is also enabled.
I changed my settings so I can see if I can reproduce this: usually I have all dark mode all the time :slight_smile: I am on a Pixel 7 Pro FWIW. I am using the position.xyz online service, not beacondb.net .
Having the same issue with graphene and l4m devices so I assume it’s an aosp problem
Yes, in addition to it not switching based on location “sunrise to sunset”, I also tested with a fixed time (e.g. dark theme from 11 pm to 6 am), and it also didn’t auto-switch. I’m checking with the team to see if they can also confirm.
