I am using iodé 4.5 and would like to automate airplane mode. I found an app called automation in F-Droid that does this on rooted phones.
Is there a way iodé can do to this without root?
Marty
Marty
How do u schedule a profile to start and end at certain times?
What I’ve been doing is setting alarms on my watch as to when phone quarantine starts and ends but there must be a 21st century answer for phones without root!![]()
Marty
That sounds like it would work! ![]()
I decided to just extend my muted notification profile to 12 hours instead of 8 hours and use self discipline not to go online during the hours I’m awake during that time! I can still get phone calls this way and it has been working to be more productive.
Marty
Automating WIFI is still possible with apps targetin older API versions - but those are no longer allowed on the Play Store
Personally, I’m using Tasker - the Play Store variant requires an additional helper APK, but I would recommend the Direct Purchase License via Patreon
The app isn’t free, so I’m not posting links
my bad, I got confused because afaik controlling wifi via apps is a common problem in the Tasker community (and genreally with automation apps)
Anyway, Tasker (at least the Direct Purchase License) can control airplane mode as well (I’m using it daily), so if you need more granular control than the on-board tools offer it could still be an option
