49h after starting iodéOS 4.7 and logging into my iodéOS premium account, I noticed that I have been logged out, which is somewhat inconvenient, because I have chosen a complicated password for this account.
So I wonder,
how long is a login into an iodéOS premium account supposed to be valid?
has the “2 day” period been implemented intentionally?
would it be possible to extend the validity period, e.g. to be valid as long as the system is not shutdown?
After an update from the API, some premium users ended up in double in the database causing daily logout issues.
I found your account and deleted the duplicate. You will now be kept logged in after you disconnect/reconnect.
@Antoine
After you deleted my duplicate from the database, I had no problem for weeks.
I have two devices. My Redfin as a daily driver and my Monet as a test device.
the monet runs without registering in the iode app.
Yesterday I wanted to test something and needed advanced functions. So I logged in to my Monet account.
And this morning I was logged out of redfin again after weeks. The monet was still logged in.
I think there are problems with using an account on two devices at the same time. Even though the license allows it.
I have now logged out of Monet and logged back into Redfin.
Let’s see what happens tomorrow morning.
I’ll write you a PM with username. Maybe you can debug something
I feel the same way, the first device runs with Premium. Then I forgot to take it with me again and switched on the second device at work. I first had to activate Premium again, which is of course inconvenient because I use sensible passwords.
Best wishes and happy holidays until 2024
It’s a bit like Dinner for One. When I switch on the second device, iodé runs in standard mode and I am prompted to improve my protection with iodéOS Premium.
Can this be changed because I have a Premium account?
I can’t reproduce the logout using 2 devices but I haven’t tested a lot. Will take a look again when I have time, @vince31fr pinging you,maybe it comes from the frontend and not the api…?
Hi all, as this is my first post here I want to thank you for this great ROM at first!!!
I have an S10 with premium account logged in without any unwanted logouts since the beginning.
The phone of my daughter is a S9 and in this one the premium account gets logged out after 1-2 days.
Both are running latest iodé and apps.
Can you maybe check if I am also facing the DB issue or let me know if I can provide additional troubleshooting ?
Seems I have the same or a similar problem on my family account. At least on the new phone of my son (Pixel 3) we need to log into premium again after a power cycle. I will check the other devices later but did not notice this on the fairphones. Any hints?
