Dear community
After installation of 4.7, Nov. 17th I get senseless auto corrections.
Something wrong, may be from my side.
Wordbook is open board
S9+
Iodeos 4.7, actual rev.
Regards
Dear community
S9+
Regards
I had a similar problem some time ago. Couldn’t fix it so installed another keyboard ( think it was simple keyboard) and everything worked again, even when it was uninstalled again.
4.7 use a fork of openboard now with a lot of improvements
best, you enter the configuration to get an overview
Not working at all
No solution yet
I had the same problem. I have turned off the system auto correction, I think it doesn’t work with the new open board. Then I only activated the auto correction in the open board settings and installed the word books for my language there.works great now for several weeks
S10+ with 4.7
Add that prediction is weak
