I’m having trouble connecting to the Aurora Store. It says:
stream was reset:PROTOCOL_ERROR
Is this happening to anybody else?
Marty
Marty
Seems to be happening since a few days also with other OS, I can currently only login using google account
On their Telegram channel they are saying
The token dispenser is curently offline (yes, for the third time), therefore anonymous login will not work for the time being. This fix may take between a few hours and a couple of days, so please have patience and bare with us.
Meanwhile, if you have a google account, you can use it to log in with it instead.
You can follow them on Telegram : Telegram: Contact @AuroraSupport
Thanks for this information. I should follow them on telegram!
Marty
This worked for me!
https://files.auroraoss.com/AuroraStore/Nightly/
AuroraStore-nightly-signed-202208180000.apk
does work.
