I purchased a Samsung S9 with iode on it.
For months now (probably since mid 2023), I’ve had difficulties opening the Aurora Store, which I have ignored so far as most of my apps are available via FDroid. But as my current DBNavigator app does not work anymore, I needed to upgrade that via Aurora.
When trying to login with any of the anonymous account options, the login fails after ~30 seconds:
When taking a look at iode’s blocker, it seems it has blocked Aurora from sending data to auroraoss.com:
Screenshot removed due to Forum media limit for new users:
After switching off iode’s blocker, Aurora instantly returns a maintenance message:
I retried logging in for a few hours, always with the same result, and the same is true after rebooting the S9 and on another day.
This was happening with the current iode OS 4.9 and the most recent Aurora 4.4.1, as well as at least with iode 4.7 and Aurora 4.3.x.
I then uninstalled Aurora via Settings|Apps|Pre-installed apps, rebooted the phone and installed it via FDroid instead.
Login attempts still produce failures to connect to auroraoss.com after 30 seconds when iode’s blocker is active.
But disabling iode’s blocker now allows Aurora to login successfully,
I’d appreciate if Aurora Store would not be blocked.
Should/would I need to buy iode’s premium account to allow me to whitelist Aurora?
