Apps wont listen microphone
I can make calls just fine, however apps wont record anything from mine mic. Which means that I cannot record any audio in recording apps or make calls in apps like Signal or Telegram.
If I plug headphones with mic, it works fine. I would blame faulty microphone, but its not my case, because native calls works fine. Permissions for microphone access for those apps is on - external mic would not work otherwise.
Any idea what could be wrong? Galaxy S10e, IodéOS 4.17
