This didn’t work on my device. Still the same problem as described above.
Did you try, as I did, to flash back to stock Android for your device then reflash with Iode?
The tool is only compatible with Google Pixel. I will try to flash Android manually and re-install iodéOS now.
Thanks so much! Manually flashing Android helped for me as well.
Which version of Android did you flash back to? I flashed the Fairphone with Android 14. Wehn I installed iodéOS for the first time, I upgraded to Android 15 shortly before that.
From Android 14 now everthing worked perfectly. The screen lock problem is gone as well.
I didn’t stay on Android long enough to look but I think it was Android 16.
