Strange because the only place I can find the words ‘play’ and ‘store’ appearing are in the comments section. I can only assume that your assumption that “This is about Play Store apps” is just your interpretation of what it’s about.
Aurora maybe, if you are desperate, but ‘Play Store’ apps should be removed from the list IMHO.
Based on the lists, you can also see well which apps users use and maybe try something out for their own ideas.
As far as compatibility is concerned, it is of course important to see which Play Store apps Aka Aurora Store apps are running or not running at all. I think this in a separate list is good.
The only apps that cause compatibility issues are those from the Play Store. Apps from F-Droid will work as long as they support the Arch and Android versions.
It’s the same thing. Aurora Store is an unofficial client for Google Play; they’re still Play Store apps. There are exactly three Aurora apps: Aurora Store, Aurora Store Nightly and Aurora Droid.
I am more than aware of that but it still saddens me to see supposed FOSS supporters referring to them on a FOSS site that uses a FOSS forum, pretending to be FOSS enthusiasts labelling them as ‘play store’ app’s. As I said in my earlier post…… ‘aurora maybe, if you are desperate’.
I believe it fair to say that people that want all the benefits that a FOSS OS brings whilst cherry picking from the big G, hold the wider FOSS app dev’s community back, or am I the only person on here that looks forward to the day that google finally pull the plug?
But you are aware that this is not happening offline? You send your voice and the content of the conversation to the Google servers. …
the app to ban access to the Internet is just a suggestion from me to get privacy.
I do Translations with Deepl (way more better translations). Since last month it was also more or less privacy-friendly as the data was processed on their own servers in accordance with the GDPR. But now they use AWS for scaling (officially in accordance with GDPR).
Details: I am on @petefoth iode unofficial build. All the app which I installed from Aurora Store shows installed from Aurora Store in Settings, but on termux with root (pm list packages -i | grep bkash) shows com.android.vending . that’s why one of my banking app named bKash worked perfectly in iode unlike official los (error: please update your app from play store; no root module didn’t work).
Questions:
is that megical modification is by lineage for microg or iode?
And how thay make the modification, or take help from any module or any project? (I want to know it because I will apply it on the official Los and give a try with that mobile banking app)
This list is getting longer and longer. It would be nice to be able to filter by category and by which apps work and which don’t.
Is there a way to do that?
It also (primarily) needs broken up as the table has reached “max rows”. I have exported it to text and will do a bit of grep / awk / sed hackery to put it into a few separate tables. But the format here doesn’t allow filtering and sorting. I have discussing with the team an alternate way to have various user-editable lists for this and other reference things (a wiki would be good but then yet another place for people to go to with a separate signup and management? But no better idea at present).
