Installed : Google App / Google Maps / Android Auto
Launched Android Auto
…Stuck at Android Auto launcher.
Below are the logs :
07-21 00:12:25.191 16269 16305 I MicroDetectionWorker: #startMicroDetector [speakerMode: 0]
07-21 00:12:25.202 16269 16305 W ErrorReporter: reportError [type: 211, code: 393244, bug: 0]: errorCode: 393244, engine: 0
07-21 00:12:25.208 16269 16305 I MicroDetector: Keeping mic open: false
07-21 00:12:25.208 16269 16305 I MicroDetectionWorker: #onError(false)
07-21 00:12:25.320 285 4872 D audio_hw_primary: start_output_stream: enter: stream(0xb0858000)usecase(4: audio-ull-playback) devices(0x2)
07-21 00:12:25.320 285 4872 D audio_hw_primary: start_output_stream: enter: usecase(4: audio-ull-playback) devices(0x2)
07-21 00:12:25.320 285 4872 D audio_hw_primary: select_devices: out_snd_device(2: speaker) in_snd_device(0: )
07-21 00:12:25.320 285 4872 W msm8974_platform: Codec backend bitwidth 16, samplerate 48000
07-21 00:12:25.321 285 4872 D hardware_info: hw_info_append_hw_type : device_name = speaker
07-21 00:12:25.321 285 4872 I msm8974_platform: platform_send_audio_calibration: sending audio calibration for snd_device(2) acdb_id(15)
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_audio_cal, acdb_id = 15, path = 0
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_adm_topology
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TOPOLOGY_ID
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_asm_topology
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TOPOLOGY_ID
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_audtable
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TABLE
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_CAL
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_audvoltable
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_GAIN_DEP_STEP_TABLE
07-21 00:12:25.321 285 4872 D : Failed to fetch the lookup information of the device 0000000F
07-21 00:12:25.321 285 4872 E ACDB-LOADER: Error: ACDB AudProc vol returned = -19
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_VOL_CAL
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> send_afe_cal
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_COMMON_TABLE
07-21 00:12:25.321 285 4872 E ACDB-LOADER: Error: ACDB AFE returned = -19
07-21 00:12:25.321 285 4872 D ACDB-LOADER: ACDB -> AUDIO_SET_AFE_CAL
07-21 00:12:25.321 285 4872 D audio_route: Apply path: speaker
07-21 00:12:17.671 672 672 V SettingsProvider: Notifying for 0: content://settings/system/screen_brightness
07-21 00:12:25.322 672 3303 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.google.android.projection.gearhead/com.google.android.gearhead.vanagon.VnLaunchPadActivity bnds=[35,258][287,554]} from uid 10037
07-21 00:12:25.330 285 4872 D audio_route: Apply path: audio-ull-playback
07-21 00:12:25.331 285 4872 D audio_hw_primary: select_devices: done
07-21 00:12:25.376 672 1375 I ActivityManager: Start proc 18062:com.google.android.projection.gearhead:vanagon/u0a93 for activity com.google.android.projection.gearhead/com.google.android.gearhead.vanagon.VnLaunchPadActivity
07-21 00:12:25.411 672 15876 W ActivityManager: Request to remove task ignored for non-existent task 31
07-21 00:12:25.465 18062 18062 I MultiDex: VM with version 2.1.0 has multidex support
07-21 00:12:25.466 18062 18062 I MultiDex: install
07-21 00:12:25.466 18062 18062 I MultiDex: VM has multidex support, MultiDex support library is disabled.
07-21 00:12:25.467 18062 18062 W Primes : Primes not initialized, returning default (no-op) Primes instance which will ignore all calls. Please call Primes.initialize(...) before using any Primes API.
07-21 00:12:25.469 18062 18062 I CAR.GH : onCreate
07-21 00:12:25.478 16269 16313 I PBSessionCacheImpl: Deleted sessionId[71553382334609986] from persistence.
07-21 00:12:25.510 12264 12264 D GmsDummySvc: onBind: Intent { act=com.google.android.gms.phenotype.service.START pkg=com.google.android.gms }
07-21 00:12:25.540 18062 18062 I CAR.GH : Process: VANAGON
07-21 00:12:25.547 16269 16305 W SearchServiceCore: Abort, client detached.
07-21 00:12:25.570 12264 12277 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:message_change_filter_blacklist value=null
07-21 00:12:25.573 12264 13363 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:frx_gearhead_package value=com.google.android.projection.gearhead:39585000
07-21 00:12:25.576 12264 12277 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:frx_maps_package value=com.google.android.apps.maps:952000000
07-21 00:12:25.578 12264 12276 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:frx_gsa_package value=com.google.android.googlequicksearchbox:300758200
07-21 00:12:25.581 12264 12292 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:frx_music_package value=
07-21 00:12:25.585 12264 13363 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:frx_tts_package value=com.google.android.tts:210307100
07-21 00:12:25.609 18062 18062 I GH.CallAdapterFactory: creating call adapter instance
07-21 00:12:25.609 18062 18062 I GH.CallAdapterFactory: useCompat().
07-21 00:12:25.610 12264 12277 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:telecom_stack value=null
07-21 00:12:25.610 18062 18062 I GH.CallAdapterFactory: useCompat=false, Device running M or later, assuming a healthy telecom stack.
07-21 00:12:25.631 3239 3239 W StaticLayout: maxLineHeight should not be -1. maxLines:1 lineCount:1
07-21 00:12:25.636 17430 17430 I GH.SharedService: Shared Service created
07-21 00:12:25.642 12264 12264 D GmsCarSvc: onBind: Intent { act=com.google.android.gms.car.service.START pkg=com.google.android.gms }
07-21 00:12:25.645 12264 12292 D SafeParcel: Unknown field num 10 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.646 12264 12292 D SafeParcel: Unknown field num 11 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.646 12264 12292 D SafeParcel: Unknown field num 12 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.646 12264 12292 D SafeParcel: Unknown field num 13 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.646 12264 12292 D GmsCarSvc: bound by: GetServiceRequest{serviceId=CAR, gmsVersion=18003000, packageName='com.google.android.projection.gearhead', extras=Bundle[{client_name=car-1-0}]}
07-21 00:12:25.648 18062 18062 I GH.CarClientManager: Gearhead Car Service not enabled. Skipping initialization.
07-21 00:12:25.693 18062 18062 I GH.CONFIG: groups:
07-21 00:12:25.694 12264 12276 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_everyone value=true
07-21 00:12:25.696 18062 18062 I GH.CONFIG: everyone
07-21 00:12:25.697 12264 12292 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_googler value=null
07-21 00:12:25.698 12264 12276 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_dogfood value=null
07-21 00:12:25.700 12264 12277 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_partner value=null
07-21 00:12:25.701 12264 13363 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_engineer value=null
07-21 00:12:25.702 12264 12292 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_demo value=null
07-21 00:12:25.702 12264 12276 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_oem value=null
07-21 00:12:25.703 12264 12277 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_developer value=null
07-21 00:12:25.704 12264 13363 D GmsServicesProvider: query caller=com.google.android.projection.gearhead name=gearhead:group_partner_qa value=null
07-21 00:12:25.751 18062 18062 D OpenGLRenderer: Skia GL Pipeline
07-21 00:12:25.768 12264 12292 D SafeParcel: Unknown field num 10 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.769 12264 12292 D SafeParcel: Unknown field num 11 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.769 12264 12292 D SafeParcel: Unknown field num 12 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.769 12264 12292 D SafeParcel: Unknown field num 13 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:25.769 12264 12292 D GmsDummySvc: bound by: GetServiceRequest{serviceId=PHENOTYPE, gmsVersion=18003000, packageName='com.google.android.projection.gearhead', extras=Bundle[{}]}
07-21 00:12:25.779 3239 3239 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
07-21 00:12:25.788 18062 18097 I Adreno-EGL: <qeglDrvAPI_eglInitialize:379>: EGL 1.4 QUALCOMM build: Nondeterministic_AU_msm8974_LA.BF.1.1.3_RB1__release_AU (I741a3d36ca)
07-21 00:12:25.788 18062 18097 I Adreno-EGL: OpenGL ES Shader Compiler Version: E031.29.00.00
07-21 00:12:25.788 18062 18097 I Adreno-EGL: Build Date: 04/04/16 Mon
07-21 00:12:25.788 18062 18097 I Adreno-EGL: Local Branch: mybranch19053788
07-21 00:12:25.788 18062 18097 I Adreno-EGL: Remote Branch: quic/LA.BF.1.1.3_rb1.12
07-21 00:12:25.788 18062 18097 I Adreno-EGL: Local Patches: NONE
07-21 00:12:25.788 18062 18097 I Adreno-EGL: Reconstruct Branch: NOTHING
07-21 00:12:25.794 18062 18097 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
07-21 00:12:25.795 18062 18097 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
07-21 00:12:25.795 18062 18097 I OpenGLRenderer: Initialized EGL, version 1.4
07-21 00:12:25.795 18062 18097 D OpenGLRenderer: Swap behavior 1
07-21 00:12:25.802 18062 18097 W Adreno-EGL: <qeglDrvAPI_eglGetConfigAttrib:607>: EGL_BAD_ATTRIBUTE
07-21 00:12:25.806 297 297 E WifiHAL : wifi_get_logger_supported_feature_set: Error -3 happened.
07-21 00:12:25.807 297 297 E WifiHAL : wifi_get_logger_supported_feature_set: Error -3 happened.
07-21 00:12:25.811 18062 18097 W Adreno-EGL: <qeglDrvAPI_eglGetConfigAttrib:607>: EGL_BAD_ATTRIBUTE
07-21 00:12:25.813 18062 18097 D vndksupport: Loading /vendor/lib/hw/gralloc.msm8974.so from current namespace instead of sphal namespace.
07-21 00:12:25.833 18062 18097 D vndksupport: Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from current namespace instead of sphal namespace.
07-21 00:12:25.834 18062 18097 D vndksupport: Loading /vendor/lib/hw/gralloc.msm8974.so from current namespace instead of sphal namespace.
07-21 00:12:25.850 672 1372 I ActivityManager: Displayed com.google.android.projection.gearhead/com.google.android.gearhead.vanagon.VnLaunchPadActivity: +518ms
07-21 00:12:25.926 306 437 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{40d00aa token=Token{c0ef795 ActivityRecord{c521b4c u0 com.google.android.projection.gearhead/com.google.android.gearhead.vanagon.VnLaunchPadActivity t32}}})/@0xf20fb02 - animation-leash#0
07-21 00:12:25.926 306 437 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{dc5f633 token=Token{96d99a2 ActivityRecord{2cef96d u0 com.android.launcher3/.lineage.LineageLauncher t6}}})/@0x4e6b376 - animation-leash#0
07-21 00:12:25.926 306 437 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{40d00aa token=Token{c0ef795 ActivityRecord{c521b4c u0 com.google.android.projection.gearhead/com.google.android.gearhead.vanagon.VnLaunchPadActivity t32}}})/@0xf20fb02 - animation-leash#0
07-21 00:12:25.926 306 437 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{dc5f633 token=Token{96d99a2 ActivityRecord{2cef96d u0 com.android.launcher3/.lineage.LineageLauncher t6}}})/@0x4e6b376 - animation-leash#0
07-21 00:12:26.003 18062 18062 I GH.LifetimeManager: connectToCarService
07-21 00:12:26.011 12264 12276 D SafeParcel: Unknown field num 10 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:26.011 12264 12276 D SafeParcel: Unknown field num 11 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:26.011 12264 12276 D SafeParcel: Unknown field num 12 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:26.011 12264 12276 D SafeParcel: Unknown field num 13 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:26.012 12264 12276 D GmsCarSvc: bound by: GetServiceRequest{serviceId=CAR, gmsVersion=18003000, packageName='com.google.android.projection.gearhead', extras=Bundle[{client_name=car-1-0}]}
07-21 00:12:26.018 3239 3239 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
07-21 00:12:26.022 306 2084 W SurfaceFlinger: Attempting to set client state on removed layer: Splash Screen com.google.android.projection.gearhead#0
07-21 00:12:26.022 306 2084 W SurfaceFlinger: Attempting to destroy on removed layer: Splash Screen com.google.android.projection.gearhead#0
07-21 00:12:27.548 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:12:27.554 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:12:27.558 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:12:27.560 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:12:27.562 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:12:27.565 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:12:28.471 285 461 D audio_hw_primary: out_standby: enter: stream (0xb0858000) usecase(4: audio-ull-playback)
07-21 00:12:28.539 285 461 D hardware_info: hw_info_append_hw_type : device_name = speaker
07-21 00:12:28.826 672 4040 D WificondControl: Scan result ready event
07-21 00:12:28.831 672 1379 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
07-21 00:12:35.743 16269 16305 I WorkerManager: dispose()
07-21 00:12:35.752 16269 16305 W ThreadPoolDumper: Queue length for executor EventBus is now 11. Perhaps some tasks are too long, or the pool is too small.
07-21 00:12:35.783 12264 12264 D GmsDummySvc: onBind: Intent { act=com.google.android.contextmanager.service.ContextManagerService.START pkg=com.google.android.gms }
07-21 00:12:35.795 12264 12292 D SafeParcel: Unknown field num 10 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:35.795 12264 12292 D SafeParcel: Unknown field num 11 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:35.795 12264 12292 D SafeParcel: Unknown field num 12 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:35.795 12264 12292 D SafeParcel: Unknown field num 13 in com.google.android.gms.common.internal.GetServiceRequest, skipping.
07-21 00:12:35.795 12264 12292 D GmsDummySvc: bound by: GetServiceRequest{serviceId=CONTEXT_MANAGER, gmsVersion=18591000, packageName='com.google.android.googlequicksearchbox', extras=Bundle[{com.google.android.contextmanager.service.args=[B@3f17e3b}]}
07-21 00:13:07.549 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:13:07.550 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:13:07.552 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:13:07.557 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:13:07.558 344 344 W wificond: Copy constructor is only used for unit tests
07-21 00:13:07.560 344 344 W wificond: Failed to get NL80211_ATTR_EXT_FEATURES
07-21 00:13:08.787 672 4040 D WificondControl: Scan result ready event
07-21 00:13:08.793 672 1379 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
07-21 00:13:29.199 672 1372 I UsageStatsService: User[0] Flushing usage stats to disk
07-21 00:13:51.296 672 1375 I ActivityManager: Start proc 18162:com.android.dialer/u0a38 for service com.android.dialer/com.android.voicemail.impl.StatusCheckJobService
07-21 00:13:51.320 16269 16269 I BgTaskExecutorImpl: Starting PERIODIC background task UPLOAD_AUDIO_LOGS.
07-21 00:13:51.327 16269 16269 I BgTaskExecutorImpl: Starting PERIODIC background task MDH_WIPEOUT.
07-21 00:13:51.330 16269 16269 I BgTaskExecutorImpl: Starting PERIODIC background task UPDATE_GSERVICES_CONFIG.
07-21 00:13:51.337 13571 18180 D NetworkSecurityConfig: No Network Security Config specified, using platform default
07-21 00:13:51.372 672 4040 W ActivityManager: Background start not allowed: service Intent { cmp=com.google.android.googlequicksearchbox/com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive$KeepAliveService } to com.google.android.googlequicksearchbox/com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive$KeepAliveService from pid=16269 uid=10092 pkg=com.google.android.googlequicksearchbox startFg?=false
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: Attempting to start service when the app is in background is not allowed on Android O+. Intent: Intent { cmp=com.google.android.googlequicksearchbox/com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive$KeepAliveService }
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: java.lang.IllegalStateException: Not allowed to start service Intent { cmp=com.google.android.googlequicksearchbox/com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive$KeepAliveService }: app is in background uid UidRecord{7c5a9c5 u0a92 TRNB bg:+1m25s426ms idle change:uncached procs:1 seq(0,0,0)}
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at android.app.ContextImpl.startServiceCommon(ContextImpl.java:1577)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at android.app.ContextImpl.startService(ContextImpl.java:1532)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at android.content.ContextWrapper.startService(ContextWrapper.java:664)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive.a(SourceFile:62)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.keepalive.StandaloneKeepAlive.a(SourceFile:9)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.search.core.service.bp.a(SourceFile:18)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.search.core.service.am.run(Unknown Source:8)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.libraries.gsa.m.a.j.run(Unknown Source:2)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.ci.a(SourceFile:2)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.cf.run(SourceFile:5)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.ap.a(SourceFile:7)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.as.run(Unknown Source:2)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.i.run(Unknown Source:3)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:458)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.util.concurrent.FutureTask.run(FutureTask.java:266)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:301)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at java.lang.Thread.run(Thread.java:764)
07-21 00:13:51.373 16269 16305 E StandaloneKeepAlive: at com.google.android.apps.gsa.shared.util.c.b.l.run(SourceFile:6)
07-21 00:13:51.376 16269 16295 W RlzHelperImpl: RlzAppProvider unavailable
07-21 00:13:51.404 16269 16335 I GservicesUpdateTask: Updating Gservices keys
07-21 00:13:51.411 12264 12276 D GmsServicesProvider: query caller=com.google.android.googlequicksearchbox prefix=qsb: name=qsb:action_discovery_data_uri value=https://www.gstatic.com/android/voicesearch/help/help_action_1377256643_%s
07-21 00:13:51.418 12264 13363 D GmsServicesProvider: query caller=com.google.android.googlequicksearchbox name=device_country value=de
07-21 00:13:51.426 12264 12292 D GmsServicesProvider: query caller=com.google.android.googlequicksearchbox name=gms_disable:com.google.android.ears value=null
07-21 00:13:51.430 12264 13363 D GmsServicesProvider: query caller=com.google.android.googlequicksearchbox name=gms.udc.ctx_mgr_enabled value=null
07-21 00:13:51.437 16269 16297 I S3UtteranceSender: send account: %s, modelType: %d[null, 1]
07-21 00:13:51.443 18162 18162 I Dialer : DialerExecutorModule.newThread - creating low priority thread
07-21 00:13:51.447 16269 16305 W SearchServiceCore: Abort, client detached.
07-21 00:13:51.452 18162 18162 I Dialer : CallLogFramework.registerContentObservers - enter
07-21 00:13:51.454 18162 18162 I Dialer : CallLogFramework.registerContentObservers - not registering content observers
07-21 00:13:51.457 18162 18162 I Dialer : DialerExecutorModule.newThread - creating low priority thread
07-21 00:13:51.471 16269 16305 W SearchServiceCore: Abort, client detached.
07-21 00:13:51.500 16269 18199 V MDH : Opening MDH wipeout table.
07-21 00:13:51.848 13571 18180 I cr_VariationsSeedFetch: Fetched first run seed in 518 ms
Willing to help by testing.
