Hi everyone,
I could use some advice about installing iode OS from /e/ OS, I assume mostly its the same as installing from stock OS, except I wont have to unlock the phone with the code from Fairphone’s website again.
So following the install guide and based on the release page, I have a few questions .
I assume I can use avb_custom_key-FP4.bin dated Jan 31st ?
Can I use the recovery image dated Feb 6th even though it shows iode 4.0 ?
Which OS image should I use , the FP4-fastboot.zip or the FP4.zip ?
as long as I don’t unlock critical partitions , the chance of bricking is relatively low, is this right?
thanks in advance for the advice
