About the Issues category
Before creating an issue here please search through the Issues and Issues-Closed categories to ensure you are not creating a duplicate.
A few notes on using the New Issue template (used when creating a new Post in the “Issues” category):
  • Replace the (enter here...) text with your information for each item.
  • Any template lines beginning with <!-- are only visible when editing and are there for your guidance: there is NO NEED to remove them.
  • If you are uncertain how to fill out this template completely, then please post your issue to the broader “System and Apps” category for discussion or guidance on creating an issue, then come back here later after you are able to fill out the template completely.
Note that posts in the Issues category may be edited, re-categorized, or even deleted in order to streamline the effectiveness of them for our development team.
