Google Pixel 8 Pro Bootloop
Good morning,
I’m having a problem installing.
There are errors in the log and at the end, I don’t have the question of choosing to relock, the phone tries to start on iodéOS but after 1 min on the “android” screen, it turns off and restarts .
Thank you in advance for your help :slight_smile:
Here is the log:
Résumé
./flash-all.sh
mke2fs 1.46.6 (1-Feb-2023)
Creating filesystem with 16384 4k blocks and 16384 inodes
Allocating group tables: done
Writing inode tables: done
Sending ‘metadata’ (76 KB) OKAY [ 0.002s]
Writing ‘metadata’ OKAY [ 0.005s]
Finished. Total time: 0.029s
Erasing ‘metadata’ OKAY [ 0.005s]
Finished. Total time: 0.006s
Info: Disable heap-based policy
Info: Debug level = 1
Info: Trim is disabled
Info: Set conf for android
Info: Enable Project quota
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 479891624 (234322 MB)
Info: add quota type = 0 => 4
Info: add quota type = 1 => 5
Info: add quota type = 2 => 6
Info: format version with
“6.5.0-26-generic”
[f2fs_init_sit_area: 640] Filling sit area at offset 0x00600000
[f2fs_init_nat_area: 674] Filling nat area at offset 0x01a00000
[f2fs_write_root_inode:1292] Writing root inode (hot node), 2c000 0 200 at offset 0x00180224
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c601, 0002c602
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180225
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c603, 0002c604
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180226
[f2fs_write_default_quota:1368] Writing quota data, at offset 0002c605, 0002c606
[f2fs_write_qf_inode:1425] Writing quota inode (hot node), 2c000 0 200 at offset 0x00180227
[f2fs_update_nat_root:1479] Writing nat root, at offset 0x00001a00
[f2fs_add_default_dentry_root:1676] Writing default dentry root, at offset 0x0002c600
Info: Overprovision ratio = 0.300%
Info: Overprovision segments = 351 (GC reserved = 340)
[f2fs_write_check_point_pack: 837] Writing main segments, cp at offset 0x00000200
[f2fs_write_check_point_pack: 993] Writing Segment summary for HOT/WARM/COLD_DATA, at offset 0x00000201
[f2fs_write_check_point_pack:1020] Writing Segment summary for HOT_NODE, at offset 0x00000202
[f2fs_write_check_point_pack:1032] Writing Segment summary for WARM_NODE, at offset 0x00000203
[f2fs_write_check_point_pack:1043] Writing Segment summary for COLD_NODE, at offset 0x00000204
[f2fs_write_check_point_pack:1051] Writing cp page2, at offset 0x00000205
[f2fs_write_check_point_pack:1071] Writing NAT bits pages, at offset 0x000003fe
[f2fs_write_check_point_pack:1092] Writing cp page 1 of checkpoint pack 2, at offset 0x00000400
[f2fs_write_check_point_pack:1111] Writing cp page 2 of checkpoint pack 2, at offset 0x00000405
[f2fs_write_super_block:1144] Writing super block, at offset 0x00000000
Info: format successful
Sending ‘userdata’ (97 KB) OKAY [ 0.003s]
Writing ‘userdata’ OKAY [ 0.173s]
Finished. Total time: 0.487s
Erasing ‘userdata’ OKAY [ 0.122s]
Finished. Total time: 0.123s
Sending ‘modem_b’ (102252 KB) OKAY [ 2.986s]
Writing ‘modem_b’ OKAY [ 0.166s]
Finished. Total time: 3.247s
Bootloader Version…: ripcurrent-14.1-11208047
Baseband Version…: g5300i-230927-231102-B-11040898
Serial Number…: xxx
Setting current slot to ‘b’ OKAY [ 0.086s]
extracting boot.img (64 MB) to disk… took 0.207s
Sending ‘boot_b’ (65536 KB) OKAY [ 1.900s]
Writing ‘boot_b’ OKAY [ 0.118s]
extracting init_boot.img (8 MB) to disk… took 0.026s
archive does not contain ‘init_boot.sig’
Sending ‘init_boot_b’ (8192 KB) OKAY [ 0.242s]
Writing ‘init_boot_b’ OKAY [ 0.015s]
extracting dtbo.img (16 MB) to disk… took 0.057s
Sending ‘dtbo_b’ (16384 KB) OKAY [ 0.483s]
Writing ‘dtbo_b’ OKAY [ 0.029s]
archive does not contain ‘dt.img’
extracting pvmfw.img (1 MB) to disk… took 0.007s
archive does not contain ‘pvmfw.sig’
Sending ‘pvmfw_b’ (1024 KB) OKAY [ 0.028s]
Writing ‘pvmfw_b’ OKAY [ 0.006s]
archive does not contain ‘recovery.img’
extracting vbmeta.img (0 MB) to disk… took 0.000s
Sending ‘vbmeta_b’ (8 KB) OKAY [ 0.000s]
Writing ‘vbmeta_b’ OKAY [ 0.004s]
extracting vbmeta_system.img (0 MB) to disk… took 0.000s
archive does not contain ‘vbmeta_system.sig’
Sending ‘vbmeta_system_b’ (8 KB) OKAY [ 0.001s]
Writing ‘vbmeta_system_b’ OKAY [ 0.004s]
extracting vbmeta_vendor.img (0 MB) to disk… took 0.000s
archive does not contain ‘vbmeta_vendor.sig’
Sending ‘vbmeta_vendor_b’ (4 KB) OKAY [ 0.000s]
Writing ‘vbmeta_vendor_b’ OKAY [ 0.004s]
extracting vendor_boot.img (64 MB) to disk… took 0.190s
archive does not contain ‘vendor_boot.sig’
Sending ‘vendor_boot_b’ (65536 KB) OKAY [ 1.949s]
Writing ‘vendor_boot_b’ OKAY [ 0.118s]
extracting vendor_kernel_boot.img (64 MB) to disk… took 0.155s
archive does not contain ‘vendor_kernel_boot.sig’
Sending ‘vendor_kernel_boot_b’ (65536 KB) OKAY [ 1.963s]
Writing ‘vendor_kernel_boot_b’ OKAY [ 0.125s]
extracting super_empty.img (0 MB) to disk… took 0.000s
extracting product.img (1264 MB) to disk… took 4.896s
[liblp] Partition product_b will resize from 0 bytes to 1325514752 bytes
extracting system.img (826 MB) to disk… took 3.605s
[liblp] Partition system_b will resize from 0 bytes to 867106816 bytes
extracting system_dlkm.img (10 MB) to disk… took 0.027s
[liblp] Partition system_dlkm_b will resize from 0 bytes to 10964992 bytes
extracting system_ext.img (406 MB) to disk… took 1.729s
[liblp] Partition system_ext_b will resize from 0 bytes to 425959424 bytes
extracting system_other.img (15 MB) to disk… took 0.077s
[liblp] Partition system_a will resize from 0 bytes to 16416768 bytes
extracting vendor.img (794 MB) to disk… took 3.419s
[liblp] Partition vendor_b will resize from 0 bytes to 833581056 bytes
extracting vendor_dlkm.img (26 MB) to disk… took 0.083s
[liblp] Partition vendor_dlkm_b will resize from 0 bytes to 27418624 bytes
archive does not contain ‘vendor_other.img’
Sending sparse ‘super’ 1/14 (254972 KB) OKAY [ 7.177s]
Writing ‘super’ OKAY [ 0.349s]
Sending sparse ‘super’ 2/14 (254972 KB) OKAY [ 7.515s]
Writing ‘super’ OKAY [ 0.351s]
Sending sparse ‘super’ 3/14 (254972 KB) OKAY [ 7.618s]
Sending sparse ‘super’ 4/14 (254972 KB) OKAY [ 7.774s]
Writing ‘super’ OKAY [ 0.355s]
Sending sparse ‘super’ 5/14 (254972 KB) OKAY [ 7.576s]
Sending sparse ‘super’ 6/14 (254972 KB) OKAY [ 7.487s]
Sending sparse ‘super’ 7/14 (254972 KB) OKAY [ 7.483s]
Sending sparse ‘super’ 8/14 (254972 KB) OKAY [ 7.554s]
Writing ‘super’ OKAY [ 0.357s]
Sending sparse ‘super’ 9/14 (254972 KB) OKAY [ 7.820s]
Sending sparse ‘super’ 10/14 (254972 KB) OKAY [ 7.715s]
Writing ‘super’ OKAY [ 0.350s]
Sending sparse ‘super’ 11/14 (254972 KB) OKAY [ 7.905s]
Writing ‘super’ OKAY [ 0.353s]
Sending sparse ‘super’ 12/14 (254972 KB) OKAY [ 8.215s]
Sending sparse ‘super’ 13/14 (254972 KB) OKAY [ 8.022s]
Writing ‘super’ OKAY [ 0.356s]
Sending sparse ‘super’ 14/14 (110164 KB) OKAY [ 3.404s]
Writing ‘super’ OKAY [ 0.178s]
archive does not contain ‘boot_other.img’
archive does not contain ‘odm.img’
archive does not contain ‘odm_dlkm.img’
Finished. Total time: 130.154s
< waiting for any device >
Finished. Total time: 29.024s
Warning: skip copying abl image avb footer (abl partition size: 0, abl image size: 1785856).
Sending ‘abl’ (1744 KB) OKAY [ 0.054s]
Writing ‘abl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl1 image avb footer (bl1 partition size: 0, bl1 image size: 16384).
Sending ‘bl1’ (16 KB) OKAY [ 0.002s]
Writing ‘bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl2 image avb footer (bl2 partition size: 0, bl2 image size: 536576).
Sending ‘bl2’ (524 KB) OKAY [ 0.016s]
Writing ‘bl2’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl31 image avb footer (bl31 partition size: 0, bl31 image size: 106496).
Sending ‘bl31’ (104 KB) OKAY [ 0.003s]
Writing ‘bl31’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gcf image avb footer (gcf partition size: 0, gcf image size: 8192).
Sending ‘gcf’ (8 KB) OKAY [ 0.002s]
Writing ‘gcf’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa_bl1 image avb footer (gsa_bl1 partition size: 0, gsa_bl1 image size: 32768).
Sending ‘gsa_bl1’ (32 KB) OKAY [ 0.004s]
Writing ‘gsa_bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa image avb footer (gsa partition size: 0, gsa image size: 348160).
Sending ‘gsa’ (340 KB) OKAY [ 0.014s]
Writing ‘gsa’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying ldfw image avb footer (ldfw partition size: 0, ldfw image size: 2392064).
Sending ‘ldfw’ (2336 KB) OKAY [ 0.068s]
Writing ‘ldfw’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying pbl image avb footer (pbl partition size: 0, pbl image size: 49152).
Sending ‘pbl’ (48 KB) OKAY [ 0.002s]
Writing ‘pbl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying tzsw image avb footer (tzsw partition size: 0, tzsw image size: 7917568).
Sending ‘tzsw’ (7732 KB) OKAY [ 0.252s]
Writing ‘tzsw’ FAILED (remote: ‘No such file or directory’)
Rebooting into bootloader OKAY [ 0.001s]
Finished. Total time: 0.052s
FAILED (remote: ‘invalid android images, skip locking’)
Hi Seb, Seems to have flashed OK. Try booting recovery and factory reset.
EDIT: Actually, skip that! It seems not to have flashed the avb_custom_key. Maybe you are flashing over another custom rom with their key on it. Might explain the “inavalid android images” comment at the end of the log.
Check inside the fastboot zip if there is key in there. Maybe got missed out somehow.
Hi chrisrg,
Thanks for your reply.
I did it but it doesn’t change anything :confused:
See my previous post, just edited it!
There is actually no file avb_custom_key
Where can I find this file please?
I will alert the dev. It might take a little while.
Thank you very much !
Just remembered something you could try while you are waiting: erasing the key in fastboot and rebooting. Be mindful that later when locking bootloader it will wipe the device.
fastboot erase avb_custom_key
fastboot reboot
Now the phone restarts in a loop without the “android” screen. Just a black screen then reboot.
Oh, sorry about that.
What OS are you flashing over?
Linux
I meant on the device. I guess it’s stock?
It was stock first.
Then I tried to install lineageos. It worked.
Then I tried again to install iodéOS. Bootloop again.
You could try sideloading the install zip, as opposed to the fastboot zip, in recovery (with factory reset/format data) if you can get into iode recovery (I assume that was the recovery you got up earlier).
Or else it’s a matter of waiting.
There might be more amiss than just a missing key.
I have already tried this method but without success :confused:
I will wait :wink:
Thank you very much for your help in any case!
Indeed, the avb custom key was not included in the fastboot package, this is fixed now. But what I find strange still is that the firmware does not seem to have been properly flashed from your trace (errors on abl, etc.).
Thank you for being so active!
I’ll try again and tell you
When I flashed shiba back in March my log shows exactly the same output for abl, etc!?? It’s running fine, so what does that mean?
Still bloked on “android” sceen and reboot
Here is the log :
Résumé
./flash-all.sh
“6.5.0-26-generic”
Writing ‘userdata’ OKAY [ 0.141s]
Finished. Total time: 0.478s
Erasing ‘userdata’ OKAY [ 0.119s]
Finished. Total time: 0.119s
Sending ‘modem_a’ (102252 KB) OKAY [ 3.140s]
Writing ‘modem_a’ OKAY [ 0.134s]
Finished. Total time: 3.349s
Serial Number…: xxx
Setting current slot to ‘a’ OKAY [ 0.080s]
extracting boot.img (64 MB) to disk… took 0.293s
Sending ‘boot_a’ (65536 KB) OKAY [ 1.974s]
Writing ‘boot_a’ OKAY [ 0.092s]
extracting init_boot.img (8 MB) to disk… took 0.031s
Sending ‘init_boot_a’ (8192 KB) OKAY [ 0.244s]
Writing ‘init_boot_a’ OKAY [ 0.014s]
extracting dtbo.img (16 MB) to disk… took 0.051s
Sending ‘dtbo_a’ (16384 KB) OKAY [ 0.488s]
Writing ‘dtbo_a’ OKAY [ 0.023s]
extracting pvmfw.img (1 MB) to disk… took 0.006s
Sending ‘pvmfw_a’ (1024 KB) OKAY [ 0.031s]
Writing ‘pvmfw_a’ OKAY [ 0.006s]
Sending ‘vbmeta_a’ (8 KB) OKAY [ 0.001s]
Writing ‘vbmeta_a’ OKAY [ 0.004s]
Sending ‘vbmeta_system_a’ (8 KB) OKAY [ 0.001s]
Writing ‘vbmeta_system_a’ OKAY [ 0.004s]
Sending ‘vbmeta_vendor_a’ (4 KB) OKAY [ 0.001s]
Writing ‘vbmeta_vendor_a’ OKAY [ 0.004s]
extracting vendor_boot.img (64 MB) to disk… took 0.194s
Sending ‘vendor_boot_a’ (65536 KB) OKAY [ 1.989s]
Writing ‘vendor_boot_a’ OKAY [ 0.087s]
extracting vendor_kernel_boot.img (64 MB) to disk… took 0.165s
Sending ‘vendor_kernel_boot_a’ (65536 KB) OKAY [ 2.005s]
Writing ‘vendor_kernel_boot_a’ OKAY [ 0.093s]
extracting product.img (1264 MB) to disk… took 4.431s
[liblp] Partition product_a will resize from 0 bytes to 1325514752 bytes
extracting system.img (826 MB) to disk… took 3.270s
[liblp] Partition system_a will resize from 0 bytes to 867106816 bytes
extracting system_dlkm.img (10 MB) to disk… took 0.025s
[liblp] Partition system_dlkm_a will resize from 0 bytes to 10964992 bytes
extracting system_ext.img (406 MB) to disk… took 1.690s
[liblp] Partition system_ext_a will resize from 0 bytes to 425959424 bytes
extracting system_other.img (15 MB) to disk… took 0.067s
[liblp] Partition system_b will resize from 0 bytes to 16416768 bytes
extracting vendor.img (794 MB) to disk… took 3.355s
[liblp] Partition vendor_a will resize from 0 bytes to 833581056 bytes
extracting vendor_dlkm.img (26 MB) to disk… took 0.078s
[liblp] Partition vendor_dlkm_a will resize from 0 bytes to 27418624 bytes
Sending sparse ‘super’ 1/14 (254972 KB) OKAY [ 7.817s]
Writing ‘super’ OKAY [ 0.321s]
Sending sparse ‘super’ 2/14 (254972 KB) OKAY [ 8.073s]
Sending sparse ‘super’ 3/14 (254972 KB) OKAY [ 7.741s]
Writing ‘super’ OKAY [ 0.348s]
Sending sparse ‘super’ 4/14 (254972 KB) OKAY [ 7.757s]
Sending sparse ‘super’ 5/14 (254972 KB) OKAY [ 7.403s]
Sending sparse ‘super’ 6/14 (254972 KB) OKAY [ 7.328s]
Sending sparse ‘super’ 7/14 (254972 KB) OKAY [ 8.055s]
Sending sparse ‘super’ 8/14 (254972 KB) OKAY [ 8.061s]
Sending sparse ‘super’ 9/14 (254972 KB) OKAY [ 8.094s]
Sending sparse ‘super’ 10/14 (254972 KB) OKAY [ 7.767s]
Sending sparse ‘super’ 11/14 (254972 KB) OKAY [ 8.009s]
Writing ‘super’ OKAY [ 0.359s]
Sending sparse ‘super’ 12/14 (254972 KB) OKAY [ 8.161s]
Sending sparse ‘super’ 13/14 (254972 KB) OKAY [ 8.086s]
Sending sparse ‘super’ 14/14 (110164 KB) OKAY [ 3.466s]
Writing ‘super’ OKAY [ 0.177s]
Finished. Total time: 131.971s
Finished. Total time: 22.020s
Sending ‘abl’ (1744 KB) OKAY [ 0.056s]
Sending ‘bl1’ (16 KB) OKAY [ 0.001s]
Sending ‘bl2’ (524 KB) OKAY [ 0.017s]
Sending ‘gcf’ (8 KB) OKAY [ 0.001s]
Sending ‘gsa_bl1’ (32 KB) OKAY [ 0.002s]
Sending ‘gsa’ (340 KB) OKAY [ 0.017s]
Sending ‘ldfw’ (2336 KB) OKAY [ 0.067s]
Sending ‘pbl’ (48 KB) OKAY [ 0.003s]
Sending ‘tzsw’ (7732 KB) OKAY [ 0.233s]
Finished. Total time: 0.051s
OK, spotted the problem.
The flash-all.sh is missing a couple of lines to do the erase and flash of the custom key.
Just edit the script by inserting these two lines at line 20 & 21:
$fastboot erase avb_custom_key
$fastboot flash avb_custom_key avb_custom_key-husky.bin
and try again! :crossed_fingers:
EDIT: Actually I don’t know if it’ll make a difference overall, but worth a try.
@vince31fr Would it make a difference at all?
