Hi community !
Since recently, probably last update to IodeOS 5.1 I have several times a day a small disconnection of my GSM/4G/5G for about 20s and then it comes back. Wifi is not affected.
I found Fairphone 5 sim card disconnection issues - Fairphone 5 - Fairphone Community Forum which on the first post seems to be sim card issue, but last message look very similar to mine.
Is anyone else experiencing the same issue ? Or am I the only one with a FP5@Iode ?
I do hope it is gonna be fixed, it is quite annoying since it was working very well in IodeOS 4.10+ and 5.0
PS: I tried to remove/insert the sim card and I cannot upgrade to eSIM because the sim card is my employer’s property…
All best !
