first i tried flashing iode 5.4 via twrp (after factory reset),
it says “updater process ended with ERROR: 1”.
then, i tried using odin to flash iode-5.4-recovery.img,
odin shut itself everytime i pressed start.
tried iode 5.3 as well, same result.
anyone has similar issue? or is the problem on my end?
