Dear all,
Even at minimum notch, calls sound way too loud, on speaker and on loudspeaker (fine through Bluetooth). On speaker, the sound can even be heard by other people around.
I have read that a similar problem was solved in e/OS 18.
I am running Iode 5.1 on Fairphone 4. Any ideas?
Thank you
That’s quite interesting. I am also using iodéOS 5.1 on an Fairphone 4. And the last phone calls seemed to be very loud (even at minimum setting). So: Maybe I can confirm this behaviour.
But I am not quite sure how loud it was before iodéOS 5.1.
Hmm, I cannot tell either if this is happening since Iode5.1. Maybe 5.0 . But certainly not since much before, I would have noticed.
I appreciate all the help
