Hi all,
I’m a few weeks into running iode on my FP5 and very impressed so far, but there’s an intermittent issue I’m trying to resolve and wonder if anyone else has experienced the same problem.
The environment is a Fairphone5 running iodeOS 6.6-20250723-FP5. I’m in the UK and use a physical SIM for my carrier. WiFi is a simple connection to my router’s SSID.
About once every few days I’m finding the WiFi icon shows as connected but no internet. Similarly, my carrier’s data connection also shows no internet and/or flicks rapidly between 5G/5G+ (presumably looking for a connection).
All other devices in the house are uninterrupted, so it’s not my network.
The only solution I’ve found is to restart the FP5. The moment I do, all connections are back again and at full strength, so this is something on or with the phone itself.
Diagnostically, I’d then look at what I was doing at the time it went out, but it appears - so far - to be random. It’s never the same app I’m using or, sometimes, it might be no app at all.
There are no other apps running on this phone that interfere with the network connections; I just have iode Premium active.
Has anyone experienced anything similar, and (how) did you resolve it?
Thanks in advance.
