Upgrade from LOS 23 to IODÉ 7.1
Hello
I have a smartphone OnePlus 9 shipped with LineageOS 23 based on Android 16. Is it possible to upgrade it to Iodé 7.1, also based on Android 16?
Thanks in advance
Yes.
As you are changing the operating system, you will lose your data. You can back up and restore most of your data using Seedvault.
@jmp68fr,
since you’ve already installed LineageOS 23.0 Recovery, installing iodéOS 7.x is very easy, comparable to the installation instructions here >>>
@dwainzwerg, @iodysseus
Using sideload mode after a factory reset, Iodé 7.1 is installed correctly.
Thank you for your help
