Unofficial builds for Google Pixel devices
@HandyTravis you tried following links in the well oudated “second post” (I’ll remove those links they are not valid as you found). But the first post has already has the updated links to the new download location.
By the way, I am currently uploading iodéOS v7.2 builds for newer devices and v6.12 builds for older devices, if you give me a half hour to finish pushing them up then that is the best to start with (or if you have an older one already you will get the updated builds via OTA, that is also fine of course!)
I just uploaded v7.3 for the Pixel 4a sunfish and newer, and v6.13 for older devices. Users with previous 2026 builds of mine will receive them OTA. Others can get them from the links in the top post.
Does someone of the Google Pixel Tablet (tangorpro) already has installed iodé7.3 on his device? I discovered an issue with bluetooth on my one after installing a self build update (not rik ones :sweat_smile:). Unfortunately Bluetooth refuses to work after upgrading from 7.2 to 7.3. Would be great if someone can have a look too.
