Two minor annoyances
Hello, I can not deactivate messages from iodé? I constantly get a message about Trebuchet from iodé Blocker, no matter if I am offline or online.
And every time I want to activate mobile data in the quick settings a message appears that mobile data might cost me money and I have to confirm it. This is annoying, having to confirm it every time.
The iodé blocker notification is a persistent silent notification which requires having something in the notification tray. Trebuchet is simply the “active app” (it is the Launcher so essentially no app is active).
You can fully disable the iodé blocker notifications from inside the app > Settings > Notifications if you like. There have been other discussions about this (search on Trebuchet): a possible idea is to just say “iodé blocker active” or something if there is no “real” app active. But so far no consensus was reached by the developers.
I went ahead and made an issue for this:
It is not possible to deactivate notifications for Iodé blocker.
In the app itself.
Thanks, the screenshot helps in this case… I am often not on a phone when on the forum so it is a bit more of a pain to go over, get a screenshot, warpinator it to my desktop then upload it :slight_smile:
