The lock screen clock doesen't switch to analague althouch selected in the "Display -> Screen Blanker" settings
Hello to the forum,
I noticed the following annoying little thing, which is apparently also present in the ports for the official supported devices:
The clock on the lock screen doesn’t switch to analaogue although it is set in the “Display → Screen Blanker” settings – not even after a restart.
Is this a known issue?
Regards
“Klaus”
On my device Sony XZ2 iode 6.5 that works smothly
For me, I do not see an option in Display ==> Lock screen for “Analog Clock”, but only under Display ==> Screen saver. This “Screen saver” is only activated during charging or docking and isn’t the same as the “lock screen”, so I wonder if there is some confusion in expectation?
Hi rik,
rethinking your question I think you’re right. I thought that’s the same because there is no option in the lock screen settings to change to an analogue clock…
So another question:
Is there a way to change the clock on the lock screen on my device to analogue display?
Device: Google Pixel 9 Pro
iodéOS: 6.5-20250625-caiman
I think you will need to search for a different / 3rd party lock screen provider. Sorry I have never tinkered in this area, it is a bit hard to find as all searches seem to go to clock widgets when using the phone, not the lockscreen. But it is possible I am sure :slight_smile:
