Roaming Problems
Samsung S10 with Iode 4.32
Two physical SIM cards,
one with a Spanish provider
and one with a German provider.
The German card is for the phone calls.
And mobile data is used with the Spanish card.
The APNs are set correctly on an original Android the cards work.
In APN Settings i have additional add IPv4/IPv6 for the APN-Protocol, but no improvement.
If you leave Spain, the roaming suddenly stops working.
Or the device behaves very strangely. Some social media apps work, for example, WhatsApp and Telegram and Telegram calls, but you can no longer access the Internet and e-mails don’t work either. F-Droid downloads hang, AuroraStore updates go.
It’s also possible that nothing works for minutes and suddenly data flows again, then it stops again.
The smartphone is also used in parallel as a hotspot for a notebook. It’s the same behavior there, TeamViewer suddenly doesn’t work anymore, etc.
Now, as is well known, it works with the Samsung devices for technical reasons, no calls and mobile data at the same time. Since no Voice over LTE is possible.
But that can’t really be the problem. Because at this time, when mobile data is used, no call happens.
I don’t actually see a DNS problem either, since the DNS works globally for all apps, as far as I know.
A tracert shows no abnormalities.
In Germany, for example, roaming is currently running over the Telekom network, which is also known to be the best developed, and is currently running at full swing.
In the settings of the SIM cards, “Mobile Data” and “Use Roaming of Mobile Data” on the Spanish map are activated and deactivated on the German sim-card.
Any ideas?
At least that way you can’t use the device sensibly.
Configuring multiple SIMs combined with Roaming seems similar to this issue raised previously: Dual-SIM Issues: No way to individually manage mobile data and roaming settings?
Maybe @DiTA (original poster) can at least commiserate with you, but I think it remains “less than ideal.” I don’t quite get if it is just lack of feature buildout, or if there are underlying bugs, or what. They did find this link to an unresolved bug at the LineageOS level: 22.1-20250207-NIGHTLY-DualSim: Data SIM switches back to wrong SIM randomly (beyond1lte) (#8304) · Issues · LineageOS / issues / android · GitLab
But probably this needs broader input from the wider “LineageOS + dual SIM + roaming” world, I suggested their Reddit or others suggested their Discord??
Hello, I’m the person rik mentioned above. My workaround or suggested solution, based on similar issues, is to check the APN when switching roaming networks, toggle the data connection on and off, repeatedly adjust the settings, switch the Iodé tracking firewall on and off, and restart the device from time to time. Another factor that may play a role is a work profile, if you use one.
After a while, the problems became less frequent.
Thanks for your info. I can’t test it at the moment. It’s not my device. It is a device of a friend who is currently back in Spain.
Most recently, he was able to make do with a mobile hotspot router.
We will test this remotely again in the next few weeks.
It was interesting that his wife has a similar constellation with a normal Android. And there it worked (but a different smartphone model and Android version).
Do you mean “similar consternation” (or “frustration”?) or is it something I don’t understand about the stars or maybe this is referring to the cell towers?
Regardless, it does seem that roaming and multiple sims and APNs and toggling which one is giving data etc. is a bit of a unpolished feature in LineageOS?
No, woman is not frustrated :-), it works for her. But she has a standard Android (no ASOP), but also dual SIM with German and Spanish SIM card.
She has no problems with roaming.
But my friend is a little frustrated.
He uses the smartphone very often on the go and is dependent on it working well. Starting with Magic Earth’s transition with the problems of the new interface and the initial problems there. Then the crashes with MicroG during navigation. Now the roaming problems. The Bank’s current S-PushTAN app does not work [Previous work ok).
Luckily the remote access works ,-)
