I have a Pixel 8 Pro (husky). I was reading here that you needed to downgrade to Android 15 to flash Iode, which I have done. I used the official Iode tool on Linux to flash to my phone and locked the bootloader.
All seems good, it’s currently on 1 October 2025 Android security patch. However, vendor security patch is still on 5 May 2025. So it’s quite old. I was wondering if this is normal and if there’s a way of getting it to a newer vendor security patch?
I was previously using GrapheneOS and both the Android and Vendor patches were at November. So far I am preferring Iode, it’s easier to use, more things are working and performance is better.
Thanks!
