Oxford English Dictionary
fire - verb
[1] discharge a gun or other weapon
direct (questions or statements, especially unwelcome ones) towards someone in rapid succession
[4] stimulate or excite (the imagination or an emotion)
… archaic show sudden anger
and then there’s always the imagination of the developer you mentioned above
I have installed 7.8 (on BraX3 - still waiting for it to show up on P8P), so will see if that resolves any of the mysterious behaviour with clock, etc…
So for those interested - I think I might have just had a breakthrough today - I need to investigate more BUT I think the culprit for most of the unannounced alarms I am getting is from the Developer Options debugging notifications - despite having this clearly disabled/turned off.
So this could be worth anyone with similar issues checking their notifications log (in Notifications > Notification History).
I’ll post more details and screen shots in the other thread below - as it’s not just the clock but other things like USB connections/charging…
Just to confirm iodé has nothing to do with this. It is AOSP + LineageOS upstream So it will take some trudging through the LOS issue tracker / Reddit to see if it can be confirmed / worked around.
FWIW while I was scratching round in the clock notification settings I accidentally left ON the notification for Upcoming Alarms. So i was confused when just before the morning alarm sounding, my chosen general notification sound played at FULL volume, but my setting for that notification sound is 33% volume. So there’s oddness going on …
Yes that’s the issue (or at least one of them) I’m definitely getting - these unknown alarms or notifications often come through with audio alert at maximum volume - so either bypass volume control or max it out - AND there’s no way to stop them when they happen because there’s no visible alert to tap or such… (and it happens to my ring volume occasionally for calls too).
EDIT: FWIW I just had a similar experience with a pair of SMS messages - details in other thread, but very very much the same:
Also - I’ve noted I found couple of apps (e.g. ioDroid) that have what appear to be new or additional notifications now that they may not have had back pre-7.7 (i.e. F-Droid vs. what ioDroid now has)?
